4L60E= Dead again! 2 days old
Old Jul 21, 2011 | 05:02 PM
  #41
built408's Avatar
I would love to know what the feed hole sizes are set at in this trans...
Old Jul 21, 2011 | 05:32 PM
  #42
ChevyTruck's Avatar
something else
Can you explain what you mean? I'm not following, the inputting I know about tans is the planetary.
Old Jul 21, 2011 | 07:13 PM
  #43
2BFAST's Avatar
He is referring to line pressure....bigger hole bigger bang
Old Jul 21, 2011 | 07:21 PM
  #44
silverz28camaro's Avatar
Did you mention what power you are at? and do you have a stock converter?
Old Jul 21, 2011 | 07:25 PM
  #45
ChevyTruck's Avatar
something else
I have 224 cam, worked heads, headers, underdrive crank pulley, and of course a tune. To him I did bot say how much power but I know he knows something is done cause you can hear the cam.
No I have a TrailBlazer I6 stock converter, 2200-2600 stall speed.
Old Jul 21, 2011 | 07:37 PM
  #46
How are your shifts? Pretty harsh at lower speeds? WOT? Do you know what 2nd gear servo your builder is using?
Both of your failures in those pics seem odd to me...Maybe Vince B has seen those failures?
Old Jul 21, 2011 | 07:44 PM
  #47
ChevyTruck's Avatar
something else
Like he told me, it was a manufacture defect that cause it, it should of never like that. It a clean snap.
I know I have billet 1-2 servo other then that it's blank to me.
Old Jul 21, 2011 | 07:47 PM
  #48
Its up to you and see what Vince B thinks, but even he usues the corvette servo in many high HP cars, it provised slightly softer 1-2 shifts.
Old Jul 21, 2011 | 07:59 PM
  #49
ChevyTruck's Avatar
something else
It's been in there for 2 years and still kickin
Old Jul 22, 2011 | 06:27 AM
  #50
Vince B's Avatar
Rj I have seen a reaction shaft break like that. I would question if that was a factory part or an aftermarket one. From the looks of the picture It almost appears that the shaft might have been welded in that area and then machined. Kind of a crazy break wouldn't you say! Oh well good to hear your back up and running.
2Bfast I have seen planets do what you had pictured. IMO in most cases a bearing failed and got into the gears.
