4l60 to 4l80e Swap (Small Question)
Old Nov 6, 2008 | 11:09 AM
Speed2's Avatar
Default 4l60 to 4l80e Swap (Small Question)
Hi, does there need to be any modifcation done to the cross member if I wanted to swap in this new transmission?
Ive read other people's articles doing the swap and they needed to do the modifcation but just wanted to make sure if the same applied to the 2008 GMC sierra 5.3 Regular Cab Standard Box
Im asking this because if there needed to be any modication done to the chassis then I wouldnt be able to register the car...
Thanks
Old Nov 6, 2008 | 11:24 AM
1989k1500's Avatar
You just have to do some work on the tranny cross member. I bet most people wouldnt be able to tell the difference.
And its not the frame your doign work to its just the cross member but I dont know if the classify that as part of the frame.
Old Nov 6, 2008 | 05:21 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
I don't know if its the same for the 08 but this is what I did.
Here you go:
https://www.performancetrucks.net/fo...ighlight=4l80e
Old Nov 7, 2008 | 07:28 AM
Raffman's Avatar
Here you go:
Nice pics AJ, it really is a staight forward swap just do your homework first.
Thanks again for the help with the pins.
Old Nov 7, 2008 | 12:00 PM
i did the exact same thing that lowlq4 did and it was simple i just cut the cross member a couple inches out from where it bolts to the frame and moved the center section back 6 inches and it was perfect.
Old Nov 7, 2008 | 12:58 PM
Low_LSX's Avatar
No problem Dave hope they help you out with your project.
SloSVO
Aug 11, 2015 07:33 PM
lycominghunter
Jul 29, 2015 04:24 PM
lo&sloSierra
Jul 19, 2015 10:56 AM
alex226
Jul 16, 2015 10:55 AM
lxcoupe
Jul 14, 2015 10:14 PM
