4l60 to 4l80. What am I forgetting
As best I can tell doing my research on my phone with crappy service, I'm gonna need (to)
4l80e
converter
modify my transmission crossmember
shorten driveshaft
add 2 wires for ISS
modify grey transmission connector wiring.
This can't be it. What am I leaving out, forgetting, overlooking etc?
What all needs to be changed in the tune, and will my 4l60 flexplate work??
4l80e
converter
shorten driveshaft
add 2 wires for ISS
swap the whole tranny segment in the tune, not shorten the diveshaft, but change the yoke and shorten it. Add the 2cd vss sensor to the pcm.
If you order a hybrid converter you can keep your flexplate,
you have to extend one of the trans lines.. i used some brake tubing and a compression fittings... yes you have to swap two pins in that plug.. i bought a kit from speartech.... but it is real easy to move the 2 pins.... this guy usually has some transmissions... its where i got mine... his name is sam and he is in pierre part... his number is 985-414-0892.. get the yoke/ dipstick tube/ flexplate and shifter bracket when you get the trans....
Silver8ado
04-18-2017 08:39 PM
