4l60 to 4l80. What am I forgetting
As best I can tell doing my research on my phone with crappy service, I'm gonna need (to)
4l80e converter modify my transmission crossmember shorten driveshaft add 2 wires for ISS modify grey transmission connector wiring. This can't be it. What am I leaving out, forgetting, overlooking etc? What all needs to be changed in the tune, and will my 4l60 flexplate work?? |
I don't know about grey connector, you can add the wires at the computer plug.
you need the 80 flexplate and yes def have to change tune. |
swap the whole tranny segment in the tune, not shorten the diveshaft, but change the yoke and shorten it. Add the 2cd vss sensor to the pcm.
If you order a hybrid converter you can keep your flexplate, |
looks like you got about everything.
you have to extend one of the trans lines.. i used some brake tubing and a compression fittings... yes you have to swap two pins in that plug.. i bought a kit from speartech.... but it is real easy to move the 2 pins.... this guy usually has some transmissions... its where i got mine... his name is sam and he is in pierre part... his number is 985-414-0892.. get the yoke/ dipstick tube/ flexplate and shifter bracket when you get the trans....
You can get a oem trans line from a 2500 suburban it bolts right in. Mine was $30 from the dealership. It could probably be had to next to nothing from a junkyard.
Originally Posted by white1
(Post 4454931)
