4.8 5spd clutch
Old Nov 8, 2009 | 06:49 PM
dusty4.8's Avatar
Default 4.8 5spd clutch
i went to the dragstrip friday night the clutch was working awesome no slip no noise drove it home fine wake up sat hop in the truck push clutch in while in first to start chatters really bad kind a lurches from a stand still in neurtral running it wont go into 1st or reverse very easily with out chattering but shifts thru gears with no problem driving down the road and chatters at red light in 1st and 2nd with clutch pushed in do you guys think its the clutch or the tranny and what clutch is the best to buy street/strip with bolt on only im looking at the spec stage 1
Old Nov 8, 2009 | 07:05 PM
2005 Silverado's Avatar
SPAM HUNTER
Wonder if you overheated it and maybe warped something. Do you have a link or anything for the spec clutch you found...
And what did you run at the track?
Old Nov 8, 2009 | 07:34 PM
Daryn's Avatar
Formerly darynC-10/23/10
heres some "............." use them in your mile long sentence,
try bleeding your clutch , changing your fluid, or push the pedal harder
Old Nov 8, 2009 | 08:32 PM
dusty4.8's Avatar
the links was just specclutches.com and i only ran a 15.2 on street tires
Old Nov 8, 2009 | 08:35 PM
dusty4.8's Avatar
.....10-4 on that. sorry i was in a hurry. i'am pushing the clutch all the way, and when i double pump the pedal it shifts easier, thought it maybe just the slave on the throwout bearing. the truck has a 120,000 on the stock clutch ive been beating the out of it since i bought it. how do you bleed these slave cylinders i dont see a bleeder like we run on our race cars. thanks
Old Nov 8, 2009 | 08:39 PM
SPAM HUNTER
there is a bleeder attatched to the slave, you can access it through a hole in the side of the front portion of the transmission
Old Nov 8, 2009 | 08:41 PM
dusty4.8's Avatar
thanx ill check it out
Old Nov 8, 2009 | 09:25 PM
SPAM HUNTER
This is a picture of when my slave over extended. The two holes you see are on the drivers side, and the TOP one is where the bleeder is.
Old Nov 8, 2009 | 09:27 PM
dusty4.8's Avatar
thanks very much ill bleed it out and let you know if it helped or if im just gonna order a new slave and clutch
Old Nov 10, 2009 | 04:20 PM
1CLNY2K's Avatar
May want to take a gander at your master cylinder as well. I installed a new clutch set back in march and had similar problems. I bleed the system and installed new fluid and it helped it out a lot. Pretty much elimanated my problem.
