2wd TH350, what to make it a 4wd??
Old Nov 9, 2008 | 09:05 PM
skyhighsami's Avatar
no title here
Default 2wd TH350, what to make it a 4wd??
If I have a 2wd TH350 what would it take to put a tcase on it? I have a friend that has a smokin' deal on one that is built and I would like to put it in my Samurai behind an LS1 I have. I have half ton running gear to go with it. I was thinking I can get just a tcase and bolt it up to the housing and let it ride but I am not sure if the output shaft has to be replaced. Also for this application what would be my best tcase option. Thanks
Old Nov 10, 2008 | 04:48 PM
black4.8's Avatar
you need to get a tailshaft and housing to match t case. 2wd have a longer tailshaft and don't bolt up to any t case as is. you could go to junkyard and get a 4x4 tranny and swap tailshafts. np205 would be your strongest t case choice, 203 would be lowest gearing. good luck
kyle's v
Oct 4, 2015 12:37 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
97aztecgt
Aug 13, 2015 02:11 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
MileHighSierra
Jul 22, 2015 11:19 PM
