2600 2800 or 3000
I need some Serious help with my stall. I plan to get a Fuddle, but have no idea about converters. I'm going with a 218/224 .562/.568 113 comp cam, and some mildy ported heads plus my mods in sig. I am planning on some LT's too when Pasesetter gets off their *** and gets them to fit 4x4's. Thanks for the help guys.
Oh yes, I want to break into the 13's on motor, and retain as much drivability as possible. I know my cake and eating it too.
I'd suggest at least a 3000 RPM stall. I love my Yank TT3000, but will probably step up to a Fuddle 3200 whenever I get around to beefing up the tranny.
I think stalls are like cams, you can always go a little bigger.
Personally I would go with at least a 3000 with that cam. 2600 would be way too small and the 2800 would be pulling it close. I have a slightly smaller cam than that and my 2500 verter does fairly well, but am going up to a 3000 or 3200 fuddle next month. Running 3.73 gear ratio you could probably get away with the 3000, if you had 4.10's, I would suggest the 3200. I spoke with John at fuddle about mine and he suggested the 3000 with my cam and 4.10's which go on in 2 weeks. He said if I stepped up to a bigger cam in the range that you are looking at that a 3200 would help it a bit.
for driveability i'd go with a 2800. i only went with a 3k b/c i drive the truck on the weekends and like to go to the track. on the street, it just smokes tires. if my truck was a daily driver, i would have went with a 2600 to 2800. your truck is probably heavier than mine so a 2800 or 3k should work fine.
TAPyvehc93
Dec 27, 2015 12:14 PM
