250 degrees
Old Oct 8, 2009 | 07:06 PM
anfking6908's Avatar
Default 250 degrees
ok so i installed my new trans temp gauge and its reading 250 after it gets warmed up.... does any one have any ideas on where i can get some OEM trans cooler lines?
Old Oct 8, 2009 | 07:38 PM
nonnieselman's Avatar
what gauge did you get? thats really high
Old Oct 8, 2009 | 07:49 PM
Gregg Nader's Avatar
Where did you locate the gauge sensor?
Old Oct 8, 2009 | 08:43 PM
i located on the side of the transmission above the linkage in the pressure test port the gauge is the autometer transtemp phantom 2 electric short sweep
Old Oct 8, 2009 | 09:10 PM
seems like something is wrong.. any way to hook up a scanner to see what the PCM is seeing for Trans temp?
Old Oct 8, 2009 | 09:12 PM
Circle-D's Avatar
Former Vendor
250 is way to high. Hopefully that is an error. If it is correct stop driving it.
Chris
Old Oct 8, 2009 | 09:19 PM
266* and you will get a Light on your dash from trans over temp..
Old Oct 8, 2009 | 09:54 PM
im hoping it is an error in the way i hooked it up....it has 5 connectors 2 "GND", 1"S", 1"I", and 1 "+12V" i hooked both of the GND's up to a ground, the +12V to the battery the S to the Sensor and the I to the ignition fuse.... sound about right? but its only a 5v drop across the gauge tho????
Old Oct 8, 2009 | 09:58 PM
I cant remember what sensor that gauge comes with.
Old Oct 8, 2009 | 10:03 PM
00ChevyScott's Avatar
Wearin' da big hat
It wouldn't surprize me if that was right. Brendan (low dime) has an s10 with an interceptor gauge and his temps get to the low 200s driving around in 80 degree heat. So I could definitely see a full size truck running just the cooler built into the radiator, up that high, especially in Houston.
