20's and 305s
Old Feb 12, 2008 | 01:20 AM
LEballistic's Avatar
Default 20's and 305s
im looking at getting some centerline stingrays 20.0 x 8.5 hi-polish forged wheel 5.4" backspacing.
ill be installing a hotchkis 2/4 TVS kit on the truck. can i fit 305/45/20 all around? what about 305s in back and 295 in front or 285?
what will be the ride difference with smaller tires in front?
Old Feb 12, 2008 | 07:14 AM
NegraRCSB2X4auto's Avatar
295 will but i don't know if 305 will fit.
Old Feb 12, 2008 | 12:04 PM
IceMan08's Avatar
Banned
depending on tire manufactor will determine tire size as well. ive seen a 305/40 on a 8.5" rim with a 3/4 drop. it wouldnt fit on the front with this setup
Old Feb 12, 2008 | 02:10 PM
StrokerAce03's Avatar
305/45 is about 30.8" tall so you should be fine although that's a wide *** tire.
Old Feb 12, 2008 | 02:34 PM
RandomHero's Avatar
The height isn't the problem. It's the width of the tire. Off the top of my head those tires are like 11.75" wide. Unless you're running a ton of offset(which those centerlines don't have), I can almost assure you will rub.
Old Feb 12, 2008 | 03:29 PM
jakebdb56's Avatar
those wheels are nice, but the chrome is worth the extra dollars IMO
Old Feb 12, 2008 | 07:30 PM
BlewSilverado's Avatar
I have 305/40/20 on mine with stock 8.5 ss wheels. The 305/45/20 would most likely rub on the outer lip of the front fender if you hit a large bump at speed. Mine barely did this one time. I think the back would be fine.
Old Feb 12, 2008 | 07:42 PM
RandomHero's Avatar
Again, keep in mind your rims have about 30mm of offset compared to his which have around 10mm of offset. This makes a HUGE difference in how it will rub.
Old Mar 29, 2008 | 10:16 AM
SnakeOiler's Avatar
Just my opinion, but that seems a bit dangerous as the minimum approved width for a 305/40 would be a 10" rim
You're gonna have rubbing issues. My advice would be if you are going to use those wheels and do a 2/4 TVS - go with a 265/50 all around
Old Mar 29, 2008 | 11:28 AM
Truckshop's Avatar
i have those wheels with 275 45 20 tires. if i hit a dip in the highway at speed they will hit the edge of the fenderwell. i am almost positive your will also. i have drop spindles on the front of my truck
