2" drop shackle questions and pic request
thats what i would need to level the truck out right? also dose it require anything eles, like new shocks?
i have heard that lowering the rear can screw up the angles and prevent good hook up true?
some before and after pics would be great if you got em.
the shackles are cheap and they will level the suspension by droppin the back 2"
you dont need anything else and you can do them pretty easily.
heres my before and after thread for my 02 RCSB
https://www.performancetrucks.net/fo...d.php?t=433981
It will level it and doesn't require anything else.
BUT if you want to do it right, you might need some pinion angle shims. Some trucks do have trouble with the driveline angles after install.
Werd. I had to get the 2 degree shims to stop the vibration I had from 5-25mph. Oh and if you install these yourself, get a BF hammer, a set of vice grips and a can of penetrating lube. Just a heads up mine were a bitch to get off.
