2" drop shackle questions and pic request
Old Feb 24, 2009 | 09:16 PM
colekill's Avatar
KickinAssAndTakinNames
Default 2" drop shackle questions and pic request
thats what i would need to level the truck out right? also dose it require anything eles, like new shocks?
i have heard that lowering the rear can screw up the angles and prevent good hook up true?
some before and after pics would be great if you got em.
Old Feb 25, 2009 | 08:40 AM
AudioPh1x's Avatar
the shackles are cheap and they will level the suspension by droppin the back 2"
you dont need anything else and you can do them pretty easily.
heres my before and after thread for my 02 RCSB
https://www.performancetrucks.net/fo...d.php?t=433981
Old Feb 25, 2009 | 08:45 AM
Coban's Avatar
It will level it and doesn't require anything else.
BUT if you want to do it right, you might need some pinion angle shims. Some trucks do have trouble with the driveline angles after install.
Old Feb 25, 2009 | 10:39 AM
seltaeb's Avatar
Werd. I had to get the 2 degree shims to stop the vibration I had from 5-25mph. Oh and if you install these yourself, get a BF hammer, a set of vice grips and a can of penetrating lube. Just a heads up mine were a bitch to get off.
Old Feb 25, 2009 | 11:20 AM
Coban's Avatar
Impact FTW!
The biggest pain in the *** about the install is taking off the trailer hitch to do the work.
Old Feb 26, 2009 | 08:46 PM
AudioPh1x's Avatar
haha the first sdie took me forever
Old Feb 26, 2009 | 09:13 PM
05GTO6SPEED's Avatar
if ive got a z71 and took the blocks out then got a 2" lower hanger would i need shims or shorter shocks?
Old Feb 26, 2009 | 10:35 PM
CountryGirl519's Avatar
You just switch out the drop shackles with the stock shackles and that's it.
BEFORE:
AFTER:
Old Feb 27, 2009 | 12:55 AM
95 bright teal's Avatar
When i bought my truck it had 2" shackles installed and it was level.
Pinion angle should be fine. and problems with hooking up happen with more drop, from bottoming out.
Old Feb 27, 2009 | 01:12 AM
viciousknid's Avatar
Where's the Beef?
There are also 2/4 drop pics in the Show/Shine index if you need more.
