1500hd caltrac question
Old Feb 25, 2013 | 07:13 PM
MPFD's Avatar
11 Second Truck Club
I have Caltracs on a standard 1500 with 2" drop shackles and that's it. Works great, but make sure your ready for the way its gonna make your truck ride....
Old Feb 25, 2013 | 07:28 PM
asap216's Avatar
How does your ride? Mine already has stiff suspension and I'm used to driving 1 ton dodges so if its a little rough I think it wouldn't be a problem lol. Is the install pretty straight forward? Any welding?
Old Feb 25, 2013 | 09:12 PM
MPFD's Avatar
No welding, but you will replace your rubber bushings in the front leaf spring hangers with solid aluminum bushings. If your suspension is hard now expect to feel double what you do now. After I swapped in the caltracs I chased a drive line vibration that I thought was pinion angle for two weeks. Turned out to be a drive shaft that was VERY slightly out of balance. It shook so hard at 80 mph that it set an ABS code. I pulled my drive shaft and got it rebalanced and it was better but is still not gone. With those solid aluminum bushings you will feel EVERYTHING in the drive line. It still shakes noticeable over 80 mph but not as bad as it was. I never felt the shake before the caltracs. Just make sure you are excited about hooking on slicks, cause it will. But if your expecting any better traction on radials you are wasting your time and money. After Caltracs, you will feel a dime on the road if you drive over it...
Old Feb 25, 2013 | 10:29 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Maybe you have too much preload? I've installed 5 or 6 sets in the last couple years and never had that experience. The set on my 1500 is going on 3 years old, and it rides just a little stiffer than stock, but it's definately not objectionable.
Old Feb 25, 2013 | 10:32 PM
MPFD's Avatar
you seriously can tell me that you don't think that the solid bushings don't transfer any extra vibration from the drive line?
Old Feb 25, 2013 | 10:45 PM
No, not a single complaint. And I'm very **** about things like that. The majority of my customers are too.
Old Feb 25, 2013 | 11:33 PM
asap216's Avatar
I'm probably gonna bite the bullet on a set. I've always head heard good things about them and a buddy of mines runs them on his truck and loves them. Ill keep you guys posted on this thread in a few weeks.
Justin87gn
Sep 10, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
02gmc5.3
Sep 7, 2015 08:11 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
