14 bolt question?
Old Apr 3, 2014 | 06:21 PM
hsiriyob's Avatar
Default 14 bolt question?
Will a 14 bolt axn axle with drums, accept the disc brakes from my 04 Silverado? holy beejesus the salvage yards are proud of these rears!!
Old Apr 3, 2014 | 07:52 PM
1FastBrick's Avatar
Custm2500's Rude Friend
It will, they will just be clocked different. The brake flanges run parallel to the pinion on a Drum brake rear end. On a Disc brake rear end there clocked at a 45 degree angle in relation to the pinion.
This might help some... https://www.performancetrucks.net/fo...thread-467473/
Old Apr 3, 2014 | 08:08 PM
hsiriyob's Avatar
I was about to delete my post I reread your sticky and saw that you had already answered. thanks
1FastBrick's Avatar
No problem.
Old Apr 19, 2014 | 05:44 PM
Bigbus's Avatar
To anybody who has completed and driven a 14 bolt swap: did you notice and ill effects that needed to be addressed ? Ie did the extra weight effect any handling characteristics ? Can the larger gears be felt as far as rotational losses ?
Heavier duty leaf springs needed etc ?
Old Apr 21, 2014 | 09:30 AM
JoeyGC5's Avatar
Only think I noticed was a little easier to slide the *** end out on corners. Stock 1/2 ton leafs under my truck. No real ill affects. I noticed more of a drive-train loss/feeling from the 4l80e than anything else. 3.42's in a 14 bolt suck though, I have a set of 4.10's ready to swap in.
Old Apr 24, 2014 | 06:37 AM
Bigbus's Avatar
Thanks for the info Joey !
vipergtrdj
Aug 6, 2015 10:19 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
