13s?
Old Jan 23, 2006 | 08:22 PM
slammed1500's Avatar
Question 13s?
im trying 2 make it in the 13s without a stall
im at 14.50 with LTs, ory, intake, efans,transgo,servo and tune
the truck still has the 342 gear in it
if i would change my gear 2 a 373 or 410 how much of a drop will i see in my
ET
and how much would and underdrive pulley help if any
Old Jan 23, 2006 | 08:26 PM
5.3AlmnBlk's Avatar
You probably could get 14 flat with the 4.10 if you can hook, some weight reduction is free and might get you to the 13 your looking for.
Old Jan 23, 2006 | 08:59 PM
CrabhartLS1's Avatar
why not use a stall? stock TC's are like fighting with one hand tied behind your back.
Also pullies are more of a throttle responce mod, not worth the time IMO, but they're not too expensive and may get you some time.
gears would probably help a lot, some good tires, a stall, and some weight reduction could get you into the 13s pretty easily.
Old Jan 24, 2006 | 06:58 PM
bluecajun5.3's Avatar
11 Second Truck Club
the gear will probably around 3/10's. to take full advantage of doing the gear swap is to remove some torque management from the trans.
the gear will probably around 2 to 3/10's. to take full advantage of doing the gear swap is to remove some torque management from the trans.
Old Jan 24, 2006 | 08:53 PM
ok so what stall should i go with being i have the stock cam and then what gear after? 373
should i get the eaton and gears 1st for traction problems
Old Jan 24, 2006 | 09:06 PM
SSlow 4.8's Avatar
well... are you planning on camming it ever?
Old Jan 24, 2006 | 11:31 PM
not really
Michael Halo
Jan 25, 2009 07:17 AM
vortec-dude
24
Dec 11, 2008 12:28 PM
LaSinister
Nov 23, 2006 09:03 AM
bad intentions
Nov 8, 2005 12:28 AM
mattrem
22
Nov 1, 2005 03:45 PM
