What would it take to be able to run E85?
Old Sep 25, 2012 | 04:01 PM
  #21
smokeshow's Avatar
Mod with training wheels
Old Sep 25, 2012 | 04:06 PM
  #22
oakley6575's Avatar
Thanks boys. Looks like I have a flex fuel pcm. Maybe I should add the sensor and see what happens.
Old Sep 25, 2012 | 04:10 PM
  #23
oakley6575's Avatar
Where is the fuel composition sensor mounted in a stock application?
Old Sep 25, 2012 | 04:15 PM
  #24
Atomic's Avatar
I have a gauge for that
All pcms have the alcohol content vs stoich table, but in the non-flexfuel vehicles its just a single value. If your truck is not a flex fuel truck then you do not have the right pcm.
Old Sep 25, 2012 | 04:16 PM
  #25
smokeshow's Avatar
Looks to be the trans crossmember
Old Sep 25, 2012 | 04:18 PM
  #26
oakley6575's Avatar
I dont have the stock pcm in my truck. Also I don't have the single value stoich table. It is an actual table with a single row of values based on alcohol content like you said before. Seems like I can make it work
Old Sep 25, 2012 | 04:24 PM
  #27
smokeshow's Avatar
I am noticing a problem here... For those who don't have stock fuel lines, that sensor isn't going to work. Is yours still stock? The sensor would need a new housing machined to accept AN fittings. Can be done, just further complication.
Old Sep 25, 2012 | 04:27 PM
  #28
oakley6575's Avatar
You don't think a russell fuel fitting would fit those nipples? The outlet looks smaller than the inlet but I know russell makes a few different sizes to fit fuel rails. I am running an AN fuel system so it would work great if those fittings would work
Old Sep 25, 2012 | 04:33 PM
  #29
smokeshow's Avatar
You could use an adapter. But I'm not sure how much they've got it necked down in there. Most people are paranoid about fuel line size and run dual -10s or some **** lol. It would probably be fine with adapters. That method doesn't cater to all parties though
Old Sep 25, 2012 | 04:36 PM
  #30
oakley6575's Avatar
Yea I know what your saying. I'm still NA and very conservative so those adapters would work without worry. I think I have enough injector but not quite sure. Sounds like a fun experiment
