truck intake vs ls6/ls2/ls1 intake
Old Nov 2, 2012 | 05:17 PM
06chevytruckbuild's Avatar
Default truck intake vs ls6/ls2/ls1 intake
right now currently have the stock truck intake and 36# injectors, ive been doing a lil reading here and there and hear u loose torque out the hole with a ls6 or ls1 or ls2 intake vs the truck intake i have thats stock.. i currently have the tr 228 cam with 588 lift and 112 lsa and a lil bit of head work as in 30,000 shaved and ported and polished up and the basic valve springs and push rods and a 2600 stall from circle d converters. is it worth swapping intakes right now i have the torque to get out the whole i just need some mid range to pick it back up thru second gear.. and what else do i need to change in order to change the intake if it is worth it. i appreciate the help if theres any out there cause i cant seem to figure out what to search to find the right info..
thanks again
Old Nov 2, 2012 | 06:52 PM
dmelvin's Avatar
The truck intake outflows the LS1 intake. The LS6 intake flows a little better than the truck intake. As far as I know, the only thing that will help you in the mid range is a higher stall, different heads, a smaller cam, or giggle gas.
Old Nov 4, 2012 | 10:40 AM
Ok cool I already thought about a bigger stall or nitrous but I appreciate the info
TA63
Mar 29, 2016 04:38 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
Suburban2500
Jul 14, 2015 02:10 AM
