Stock injector and fuel pump sizes for 99-02
Old Aug 24, 2013 | 12:24 PM
Camin00's Avatar
Default Stock injector and fuel pump sizes for 99-02
I think the injectors are 24lbs? don't know the flow # for fuel pump.
Could one run boost with 24lbs like 2-4psi till money comes in for the fuel upgrade?
Old Aug 24, 2013 | 04:55 PM
kbracing96's Avatar
Pretty sure the 99-00 injectors are only 19lbs/hr. I would not run stock injectors on any turbo setup. MIN would be flex fuel 36lbs but ideal are 42lbs 8.1 marine injectors.
Old Aug 24, 2013 | 08:15 PM
Ferocity02's Avatar
My '01 had 25.2# injectors, not sure on the pump.
Old Sep 11, 2013 | 01:27 AM
chris99gmc's Avatar
I'm almost positive my 00 has 24lb/hr injectors... I think I remember my 99 having only 18#ers though.
Old Sep 11, 2013 | 08:56 AM
Txblue's Avatar
How do you tell which injectors you have?
Old Sep 11, 2013 | 07:01 PM
black00chev's Avatar
Slowest turbo build ever!
The guy doing my cam swap says they should be 24s. Only way to really tell is to have them flow tested. And like Kyle said, even 24s aren't enough for anything that turbo will do. Unless you run around without the wastgate spring in that is.
As for the stock fuel pump, they aren't great, that's for sure! They should have just installed the 255 pumps from the factory!
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
