Return-Style Fuel Conversion
Old 12-12-2010, 01:28 AM
  #51
I have a gauge for that
Atomic's Avatar
Two densos fit easily, by the way
Old 12-12-2010, 01:35 AM
  #52
charcold-bowtie's Avatar
I also cut my hose at a slight angle, as I was told, so that it wouldnt end up flat on the bucket floor and cant suck fuel.
Good question about the compressed height, I think mine is about all the way down. I have to redo it anyway, Ive had a starvation issue once, at idle, that never had happened again. It wouldnt start, for about 1 minute of cranking. Then started and acted fine. But the the feed hose is currently made of 1/2inch heater hose, which needs to be replaced
Old 12-12-2010, 01:50 AM
  #53
wkdivr's Avatar
I've been considering the Denso's too. How are you going to configure the socks in the bottom of the bucket? Are you going to plumb the return into the original venturi port, or just dump it into the bucket?
Old 12-12-2010, 11:21 AM
  #54
MikeGyver's Avatar
See, I wasn't lying about how small mine is.
Old 12-12-2010, 11:29 AM
  #55
Atomic's Avatar
like this
This is picture of the sender side of the bucket, when you put this in the bucket the sock on the right folds upward like the stock sock so the socks are never overlapping. I kept the stock feed hose from the feed fitting, and since I am using the stock feed line as the return, I am having that hose dump directly back in to the bucket.
Old 12-12-2010, 11:30 AM
  #56
Atomic's Avatar
Doesnt really sound like your shinning moment, sounds more like a personal issue
Old 12-12-2010, 12:07 PM
  #57
MikeGyver's Avatar
Yeah, I have fuel bucket envy. So there's no way those pumps will fit in my bucket, right? Could you put them together and take a pic with a ruler on them?
Old 12-12-2010, 12:09 PM
  #58
MikeGyver's Avatar
Never mind, I'm just going to order them and build a surge tank if they won't fit in the bucket.
Old 12-12-2010, 12:19 PM
  #59
Atomic's Avatar
They are 50mm in diameter, so just guessing but I think two would be 100mm. I had that bucket before and after looking at it I realized it was too small and sent it back and found a returnless one on ebay.
Old 12-15-2010, 01:06 AM
  #60
Rick_Vor's Avatar
It would be cool to pick up a 1 gal plastic surge tank that could hold two pumps. Your stock pump could constantly keep it filled regardless of how low you ran your main tank and it would be easy to convert back to stock down the road.
Quick Reply: Return-Style Fuel Conversion
