Return-Style Fuel Conversion
Old 01-31-2011, 09:14 PM
  #101
I have a gauge for that
Atomic's Avatar
Eh, eventually I guess. Did I mention my trans broke at the same time? I have my turbo stuff up for sale and need to send the engine and trans back this week to get them looked at/ fixed.
Old 10-02-2011, 09:49 AM
  #102
Atomic's Avatar
I know the issue of compressed distance in the tank came up somewhere, well I finally measured yesterday and there is roughly 12 3/4" from the bottom of the tank to the bottom of the top of the hole.
Old 10-22-2013, 03:10 PM
  #103
hsiriyob's Avatar
I dont know how i missed this thread. Why does the venturi fill the bucket on a stock setup and not on a twin pump?
Old 10-22-2013, 05:32 PM
  #104
Mod with training wheels
smokeshow's Avatar
Because it would be too inconvenient to route the lines back in an OE fashion with a 2nd pump smashed in there. Without custom fabrication like the squash stuff it would almost be impossible lol. I'm not even sure if his has that functionality.
Old 11-05-2013, 01:02 AM
  #105
hsiriyob's Avatar
Is it a good idea to lower the bucket wall height so you can fill the bucket at a lower fuel level? Also when tying the pumps, y, and bulkhead together, should the bucket be compressed or elongated? Ie I'm worried it might be to tight if I don't get the length of hose just right.
Old 11-05-2013, 06:52 AM
  #106
Atomic's Avatar
Needs to be roughly the height it sits in the tank.
You want the wall height as tall as possible. The returned fuel will fill the bucket, you want it to stay as full as possible.
Old 11-05-2013, 10:22 AM
  #107
hsiriyob's Avatar
Thanks atomic! I was wondering why you stopped answering my questions on the dual setup, then I ran into this thread I'm almost done piecing mine together. Ill use your 12 3/4 measurement as a base for the height. This thread needs to move to fueling systems from forced injection.
Old 06-29-2015, 03:20 PM
  #108
TAPyvehc93's Avatar
For those of you that have converted to the return style, what are you all doing with the stock venturi? Is a return line alone enough to fill the bucket, or should I put a T after the fuel pump and tie it into the venturi?
Old 06-29-2015, 03:37 PM
  #109
Atomic's Avatar
I have the return line dump directly back into the bucket and have never had a problem with it, but the bucket is intact as well.
Fast86z
08-23-2015 12:35 AM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
jrplz
07-09-2015 12:07 AM
mrgrim
07-08-2015 08:12 AM
Quick Reply: Return-Style Fuel Conversion
