Need 04 returnless fuel sytem advice Please!!!!!
Old 06-22-2012, 11:52 AM
Default Need 04 returnless fuel sytem advice Please!!!!!
A while back I bought a corvette style filter(with internal regulator) to put on my truck along with an aeromotive 340. I bought the fittings as well, but I lost the diagram and write up that I had seen somewhere on the forum before. I have looked and cant find any info anywhere now. Can someone find a link with some info so I could finally get this put on my truck? Thanks for any help you guys can give me.
Old 06-24-2012, 01:10 PM
Fastcount03's Avatar
If you have a returnless rail and return lines, the lines will connect directly to the filter and the filter will connect to your rail. No fittings needed. Just a little bending of the rail to make room.
Old 06-24-2012, 09:48 PM
Thanks for the reply. So I just bend the rail a bit, mount the filter and just run a return back to the tank? What is a recommended line to run for the return? Just making sure because I might be doing this this weekend.
Old 06-05-2014, 08:17 PM
Go5.3tt06's Avatar
Don't u have picture for that with returnless how to do.
Old 06-06-2014, 06:24 AM
Flyingcat's Avatar
Maybe this link will help.....
https://www.performancetrucks.net/fo...ersion-471680/
Old 06-06-2014, 10:43 AM
2doorfury's Avatar
Do you have to run a return? I bought a return less fuel rail so I wouldn't have to run a return. I planned on just running a walboro 255 and a corvette regulator.. would this not work?
Old 06-06-2014, 12:35 PM
Flyingcat's Avatar
Others may know a lot more than I do, and I know they do...The returnless uses a fpr inside the bucket as a factory setup..I believe the 'Vette regulator returns the fuel back to the tank thru a seperate line...
You can see the pump, the filter, and fpr(silver top) in the bottom of my bucket...You would have to remove the internal fpr to convert to a return style if I understand it correctly...
Correct me if I am wrong on this...
Old 06-06-2014, 12:46 PM
2doorfury's Avatar
I'm looking for a setup to go on my 5.3 swap blazer. I figured the returnless rail would allow me to do away with a return line. I guess if I just run a regular fpr, I won't have to runs return. Now that I see a pic of the corvette regulator setup, I do think it does return back to the tank at the regulator.
Old 06-06-2014, 12:52 PM
Flyingcat's Avatar
This pix is of my stock truck "returnless" bucket....All factory from GM...I am not going to use a Corvette regulator...Sorry if I confused you or anyone else here....I will be installing a 255 probablly and use the stock fpr, and filter...
chevy6.0fan
08-20-2015 07:10 PM
MS3Z
07-30-2015 06:17 PM
sauldgold
07-23-2015 02:15 PM
4B11T
07-13-2015 03:48 PM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: Need 04 returnless fuel sytem advice Please!!!!!
