Modifying returnless bucket for return
Old May 27, 2016 | 12:18 AM
MikeD.'s Avatar
Default Modifying returnless bucket for return
Anyone have pictures of the returnless buckets modified to run return. I'm just trying to see what your guys are doing with the regulator/filter assembly inside. Is it totally removed or are you just keeping it in there and running directly from the pump to the top of the module? I'm going to use the stock feed as my return line, and run a new -6 as the feed.
Old May 27, 2016 | 03:53 AM
03sierraslt's Avatar
I removed everything in the bucket except for the pump.
Old May 27, 2016 | 10:40 AM
MikeD.'s Avatar
Then from there I run my new feed to the -6 bulkhead, and then just run the stock feedback into the bucket for the return?
Old May 28, 2016 | 05:07 PM
LongBlue's Avatar
Gutted everything too. 2 450 TI's in a NNBS bucket up to a bulkhead. Stock feed becomes return.
Old May 30, 2016 | 12:04 AM
XBlackXCheavyX's Avatar
Correct.
I did this tread awhile back, has some good pics, may help you out.
https://www.performancetrucks.net/forums/fuel-systems-210/return-style-walbro-400-install-questons-536454/
Old May 30, 2016 | 11:42 AM
MikeD.'s Avatar
Originally Posted by XBlackXCheavyX
Correct.
Sweet that thread was exactly what I needed. Thanks dude
Old Jun 8, 2016 | 04:17 PM
MikeD.'s Avatar
Got my bucket all wrapped up. Took some pics. I'm just leaving the stock feed tube and elbow so it dumps directly into the bucket.
Old Jun 8, 2016 | 09:16 PM
Looks good, what are you using for feed -6 or -8
Old Jun 8, 2016 | 09:48 PM
MikeD.'s Avatar
-6 feed. I'm almost feeling like I should have just done a 450 instead of the aero 340 in there now. But should still support my 600ish hp I'm making now.
Also messed up and ordered a 40 micron filter from summit, only realizing that that's not that much filter. I have a fuel lab 10 micron filter come tomorrow and getting everything wrapped up.
Old Jun 14, 2016 | 06:19 PM
Vortec350ss's Avatar
I'm in the middle of finally tackling this now... Taken me long enough to sack up and do it.
