LS2 injectors on Gen III truck intake
Old Dec 15, 2022 | 08:12 AM
redhat's Avatar
Default LS2 injectors on Gen III truck intake
I have a set of low mileage LS2 injectors that I'd like to use for an upcoming mild cam swapped 6.0 going into a 2005 Tahoe.
I have read through he ICT billet page and understand that I'll need spacers for the height different with the fuel rail, no biggie there.
My questions are with the O-ring sizes.
For the Upper Fuel Rain O-Ring, the LS2 is .533 and the Truck is .537. Is this close enough where there shouldn't be a leak? And for the bottom the difference between the .587 and .551, I am assuming I will need a different O-ring?
Old Dec 15, 2022 | 06:29 PM
68Formula's Avatar
Upper should be close enough, especially after it swells from being exposed to fuel. Key up the fuel pressure and check closely for wetting around the upper o-ring.
The lower is going to be tight, but still seal. Lubricate both the o-ring and manifold pocket with oil liberally before installation.
Old Apr 2, 2024 | 08:26 PM
Redtruck98's Avatar
Registered User
Default Ls2 injectors to lm7 intake
Any word if this worked ? I found a great deal on ls2 injectors and i want to swap them into my lm7 truck manifold i just want to make sure
Old Apr 3, 2024 | 07:12 PM
IIGW's Avatar
5 Year Member
what is the part number of the injectors?
Saying theyre Ls2 injectors doesnt really tell us anyhting.
And for trucks, the 50# 12613412's are almost the best--i say almost becuase no one says what theyre building and hp or RPMs they be turning.
Just randomly changing injectors means nothing....there has to be a why.
And dont forget the tuning that HAS to happen if you change them....
max1
May 25, 2010 12:20 PM
max1
May 11, 2010 11:27 PM
Modern_Muscle
Feb 11, 2009 07:22 PM
tdrumm
Jun 28, 2007 03:27 PM
Jeff Alexander
Oct 2, 2006 02:29 PM
