ls2 injectors
Old Oct 1, 2006 | 06:34 PM
Jeff Alexander's Avatar
Default ls2 injectors
just wondering what flow rate are the ls2 injectors and if they can be used on a ls1/6 intake manifold. I trying to research everything about the ls1/6 intake swap. the reason im asking is i can get some for cheap. thanks
Old Oct 1, 2006 | 06:48 PM
sroach20's Avatar
ls2 from a car or truck?
Old Oct 1, 2006 | 06:59 PM
6.0 from a goat
Old Oct 1, 2006 | 07:04 PM
ZR1 DREAMING's Avatar
what truck has the LS2?
Old Oct 1, 2006 | 07:09 PM
nightrunner's Avatar
Mr. Obvious
tbss and ssr
Old Oct 1, 2006 | 07:17 PM
Originally Posted by nightrunner
tbss... its kind of a truck
oh, ok.
Don't they use the car injectors though?
Old Oct 1, 2006 | 07:21 PM
Mr. Obvious
i edited the earlier post to include the ssr but i think that the tbss DOES use all car accessories and the like
Old Oct 1, 2006 | 08:06 PM
sroach20's Avatar
ls2 ssr uses truck injectors.
Old Oct 2, 2006 | 06:01 AM
bluecajun5.3's Avatar
11 Second Truck Club
i asked this awhile back and got no answer.
but i found out my answer and no you can't.
Old Oct 2, 2006 | 12:06 PM
when i did a search on the subject i found your post with no answer so i thought I ask again. thanks for the info. I think i have everything figured out on the swap, except for a few questions. If i use my truck fuel injector in rail will the injector rail mounting point be above or below the manifold mounting point. and what about if i have mechanical fans if the intake is just lowers the tb it looks like it will fit. sorry for the question but i know your going to do the swap also if you have any advise or suggestion it would be apreciated
