Low fuel pressure issue
Old May 15, 2013 | 07:20 PM
AndysC3's Avatar
Default Low fuel pressure issue
Something's up with my truck. Just got back from a 4 day trip in the field, truck started fine. About a mile down the road I notice that my fuel pressure is around 40. Should be 50 at cruise. Get home and its idling at 20. Turn it off. Turn the key to the on position to prime the system and the needle doesn't move. Hook up the second pump and I only get 10 psi to prime. Any ideas?
Old May 15, 2013 | 08:30 PM
03sierraslt's Avatar
Wiring.
Old May 16, 2013 | 12:24 AM
AndysC3's Avatar
Nope,
Split a hose
Old May 16, 2013 | 12:25 AM
AndysC3's Avatar
I haven't had any electrical problems since I changed a few things. Seeing 13.5v at cruise now.
Old May 16, 2013 | 01:15 AM
oakley6575's Avatar
That is a pretty sharp turn for that hose. I would change that fitting to a 45
Old May 16, 2013 | 05:02 AM
TIM Z's Avatar
11 sec. Truck Mod
That's what I said in the build thread .put a "y" fitting in there .
Old May 16, 2013 | 08:59 AM
nonnieselman's Avatar
or atleast a 90* fitting..
I put a -6an Y in my tank and nothing is in a bind.
Old May 16, 2013 | 09:25 AM
AndysC3's Avatar
I got it fixed with the hose walbro sends in the install kit its alittle longer than the hose I had on it. Im going to look for a better y fitting and some more of the gates hose.
Old May 16, 2013 | 10:52 AM
AndysC3's Avatar
would something like this work
Barbed Hose J [SS Hose J] : The CHI Company, New and used beverage equipment for Homebrewing, Home winemaking, Soda systems and used Pepsi vending equipment
Old May 16, 2013 | 11:46 AM
im using this one
http://www.summitracing.com/parts/sum-220107c
