injectors size for a 6.0 600 rwhp?
Old Jan 18, 2014 | 07:44 PM
redsvt1's Avatar
Registered User
Default injectors size for a 6.0 600 rwhp?
im doing a turbo Lq4 6.0 and want to be around 600rwhp but dont know wich injectors size to use.
Old Jan 18, 2014 | 08:14 PM
GMCtrk's Avatar
It depends on what fuel you will use?
For gas I would do Siemens 60s or 80s. 1000cc on E85.
Old Jan 18, 2014 | 09:10 PM
TIM Z's Avatar
11 sec. Truck Mod
Are you going to be spraying meth also ?
Old Jan 18, 2014 | 09:23 PM
redsvt1's Avatar
Registered User
only boost, and i will use gas.
Old Jan 18, 2014 | 09:31 PM
GMCtrk's Avatar
60 lb/hr injectors will suffice
Old Jan 19, 2014 | 02:09 PM
Alpinestar's Avatar
x2. A lot of people, including myself, run Siemens Deka 60lb EV1 injectors without any problems. If you go that route be sure to get the right sized o-rings and you will need EV1 connector adaptors as well. You will also have to space your fuel rails up a bit.
Old Jan 19, 2014 | 05:09 PM
roland1's Avatar
Or call fuelinjectorconnection and tell them what you have.
They sent me 60lb@43 psi injectors properly drilled spray pattern for LS engines.
Plug and play. Came with o rings on them already.
Old Jan 19, 2014 | 05:10 PM
roland1's Avatar
Also for 6.0L LQ9. They emailed me the injector data for the software I was using (HP tuners).
Was very easy dealing with them. Just told them what I was doing and they took care of the rest.
Old Jan 19, 2014 | 06:13 PM
TIM Z's Avatar
11 sec. Truck Mod
I don't feel that 60lb injectors are going to be enough to support 600rwhp without help from meth .
If that's your plan then get a set sized for your application that will let you achieve that power goal and give you some room .
I have 60#ers but without the meth I don't think they would have cut it .
Also mine are Deatchwerks plug and play. I suggest talking to them and seeing what they have for setup . I'd rather have plug and play then re-wiring /spacing if it can be avoided.
Old Jan 19, 2014 | 06:22 PM
Mangled03gmc's Avatar
Baltimore Whore
60 lbrs will prob get you there, but for safe 80# would be my choice.
