injectors size for a 6.0 600 rwhp?
im doing a turbo Lq4 6.0 and want to be around 600rwhp but dont know wich injectors size to use.
It depends on what fuel you will use?
For gas I would do Siemens 60s or 80s. 1000cc on E85. |
Are you going to be spraying meth also ?
only boost, and i will use gas.
60 lb/hr injectors will suffice
Originally Posted by GMCtrk
(Post 5183261)
Or call fuelinjectorconnection and tell them what you have.
They sent me 60lb@43 psi injectors properly drilled spray pattern for LS engines. Plug and play. Came with o rings on them already. |
Also for 6.0L LQ9. They emailed me the injector data for the software I was using (HP tuners).
Was very easy dealing with them. Just told them what I was doing and they took care of the rest. |
I don't feel that 60lb injectors are going to be enough to support 600rwhp without help from meth .
If that's your plan then get a set sized for your application that will let you achieve that power goal and give you some room . I have 60#ers but without the meth I don't think they would have cut it . Also mine are Deatchwerks plug and play. I suggest talking to them and seeing what they have for setup . I'd rather have plug and play then re-wiring /spacing if it can be avoided. |
60 lbrs will prob get you there, but for safe 80# would be my choice.
