going return style....
#52
Yes, not sure if it matters if its 6 or 8an. I have mine the same as the pic, but with the 6an fitting and line to the reg. Haven't had any problems. Just figured 1 less fitting would better since it will not be as bulky and its just another place where it can leak fuel.
#53
From the pump to the bulkhead use a -8 bulkhead with a female 5/16 barb fitting screwed to the bottom side of the bulkhead inside the tank. Then run gates 5/16 from there to pump.
#55
Redhorse 2000 08 2 8AN 8 An Straight Push Loc Hose End Black | eBay
#59
Aproxametly how long is the new feed line you guys are running ? I'm thinking of getting a string and trying to measure out a route to run it. Just need the feed line, fittings and fuel filter.
Also would it be OK to run the push style fittings with a hose clamp? Just wondering ?
