going return style....
Old 11-18-2013, 06:25 PM
  #51
darnie's Avatar
i could. i was just thinking go 8an out as well because of the fuel rail? but ur saying reduce the fitting at the rail and run a 6an line correct?
Old 11-18-2013, 06:44 PM
  #52
graysilverado5.3's Avatar
Yes, not sure if it matters if its 6 or 8an. I have mine the same as the pic, but with the 6an fitting and line to the reg. Haven't had any problems. Just figured 1 less fitting would better since it will not be as bulky and its just another place where it can leak fuel.
Old 11-18-2013, 07:15 PM
  #53
blue0453's Avatar
From the pump to the bulkhead use a -8 bulkhead with a female 5/16 barb fitting screwed to the bottom side of the bulkhead inside the tank. Then run gates 5/16 from there to pump.
Old 11-18-2013, 08:10 PM
  #54
darnie's Avatar
Ok cool thanks guys. Who sells submersible line?
Old 11-19-2013, 02:56 PM
  #55
darnie's Avatar
would this work? and just add hose clamps? also what hose would you run intank?
Redhorse 2000 08 2 8AN 8 An Straight Push Loc Hose End Black | eBay
Old 11-19-2013, 04:46 PM
  #56
blue0453's Avatar
Search gates 5/16 submersible fuel line. 5/16. Orielys has it.
Old 11-19-2013, 05:04 PM
  #57
GMCtrk's Avatar
Use factory style corrugated tube inside the tank if at all possible. It's 1/4th the price of the gates and more durable. People have had failures with the gates submersible on here.
Old 11-19-2013, 11:42 PM
  #58
darnie's Avatar
Ok thanks guys ill have to do some searching in the morning. I think i got all the parts layed out hopefully be able to order the hoses and fittings soon
Old 12-12-2013, 07:47 PM
  #59
darnie's Avatar
Aproxametly how long is the new feed line you guys are running ? I'm thinking of getting a string and trying to measure out a route to run it. Just need the feed line, fittings and fuel filter.
Also would it be OK to run the push style fittings with a hose clamp? Just wondering ?
TAPyvehc93
01-08-2016 10:47 AM
blackedoutchevy22
10-01-2015 08:07 PM
97_ek
09-23-2015 09:16 PM
Quick Reply: going return style....
