fuel system upgrade
Old Sep 30, 2013 | 04:14 PM
hsiriyob's Avatar
Default fuel system upgrade
I need to upgrade fuel in my Silverado. I want to run the Holley dominator 12-1800 in tank. Should be the same install as the twin walbros, just less plumbing. Here are the things i need help with.
700-800 rwhp goal...
1. Ill be running e-85, so tephlon coated? If so what brand?
2. -8an feed and -6an return?
3. The pump has a -10an pickup and feed. There is a company that makes a -10an fuel sock but its 55 bucks plus the ride. It is also a offset rectangular design. Since the pump is a two in one design the pickup is centered. I think a round sock would fit better. Anybody have any idea of a -10an adapter to a centered sock or know how to piece it together?
4. Adapters? Fuel rails are the fast lsxrt -8an male. The pump is -10an
5. I want to run a racetronix harness that has a hobb switch or something to activate the auxilery pump at 2-3 psi. what are my options? anything plug and play?
6. fpr? It will have to be boost referenced. I like the look of the aeromotive. does it really matter on brand or they all the same?
7. Filters?
Ill post pics up as i go and use this as a how to. thanks for any help in advance!
Old Sep 30, 2013 | 05:07 PM
Atomic's Avatar
I have a gauge for that
1. Dont have to but feel free. Keep in mind you will need special fittings for PTFE lined, which is what I think you mean.
2. I would do -10 feed and -8 return if you are planning on e85.
3. Make work the part they recommend. If the pump is -10 use -10.
4. Look on summit or jegs, plenty of adapter pieces.
5. What aux pump? You only mentioned the holley.
6. Aeromotive is good...
7. yes.
Old Sep 30, 2013 | 08:49 PM
hsiriyob's Avatar
the holly dominator is a two in one pump it looks like two walbros sandwitched together. I have a emailed holley to see what the diameter of the pump is.
Old Sep 30, 2013 | 09:08 PM
hsiriyob's Avatar
here are the dimensions.(7.5” Long x 5” Wide x 2.5” Tall) . anybody have there bed off? Will this pump fit?
Old Sep 30, 2013 | 10:02 PM
Atomic's Avatar
I think that may be too wide...why not go with two walbro450s? Be a lot easier to fit. What year is your truck?
Old Oct 1, 2013 | 06:56 AM
hsiriyob's Avatar
Truck is a 2004. The 450's are e-85 compatible correct? I can't remember if it was you atomic that did the twin walbro write up?
Old Oct 1, 2013 | 07:00 AM
GMCtrk's Avatar
The good thing about the holley is that you only have to bother with 1 fuel line. No Y's or T's in the tank. If 2 450s will fit in the bucket, the Holley should as well.
Old Oct 1, 2013 | 07:39 AM
Atomic's Avatar
Huge hassel, right?
I dont have mine out, but I dont think the hole in the top will fit a 5" pump setup.
Old Oct 1, 2013 | 08:40 AM
hsiriyob's Avatar
That's what I'm afraid of. The pump can also be mounted inline. If I do have to mount it inline, how do I do the pickup?
Old Oct 1, 2013 | 10:33 PM
Atomic's Avatar
I happen to have an 07 pump bucket laying around, measured the top and its only 4.5" wide so that holley pump will not fit.
If you want it inline I would keep the stock pump and do a surge tank with the holley.
