fuel system help
Old Jul 6, 2018 | 04:50 PM
TXsilverado's Avatar
Default fuel system help
this is for a LS swapped 69 Camaro with a fuel cell. I'd like to go with a more modern in-tank system than the typical inline.
I need enough fuel system to handle a 408 stroker with anywhere between 16-18lbs boost. I'll run 93 pump with 100% meth injection 99.99% of the time, but I'd like to have the option of running e85 if I ever got froggy.
here are the two systems I'm looking at. I see a few pros and cons of each, but ultimately I don't know enough to pull the trigger on either.
https://www.holley.com/products/fuel...s/parts/12-147
I like the price, I like the fact that there is only 1 feed. I don't like that there is no attempt at a bucket. is it enough to support my needs? do these pumps have a check valve so I can run 1 pump at idle/cruise and both when in boost?
https://www.aeromotiveinc.com/product/dual-phantom/
I like the bucket. not wild about the price, not wild about 2 outlets (not as simple), same questions as far as if the pumps have check valves that could be run separately.
I thought about trying to get my hands on a bucket from Aeromotive, then stuffing the holley setup in there. I tend to overthink things. thoughts, questions, concerns?
Old Jul 6, 2018 | 05:04 PM
Atomic's Avatar
I have a gauge for that
If the cell is sumped it shouldn't matter too much. You can always add the foam thing to the Holley.
Old Jul 6, 2018 | 08:55 PM
It is sumped for an external pump, but not internal pumps. I dont see tthat eromotive sells the foam bucket seperate.
Gbrown1320
Nov 13, 2016 10:57 AM
sprayedsilss
May 21, 2016 09:04 PM
scooter k
Apr 29, 2011 05:24 PM
Pontiac Derek
Jan 19, 2010 10:15 PM
Superado
Nov 2, 2006 08:12 AM
