fuel rail 90 hitting alternator
Old Jun 21, 2012 | 01:44 PM
GetBlown01's Avatar
Default fuel rail 90 hitting alternator
Quick question fellas. I just put the proflow xt intake and rails on. The problem im having is the front of the driver side rail 90 fitting is hitting the alternator . I have a straight npt to an with a an to push lock 90 on the rail.
Could I go with a straight cut straight to a 90 to bring it in a little, or would you guys go with a 90 straight off the rail ?
Old Jun 21, 2012 | 02:15 PM
mcfarlnd's Avatar
Un-Registered User
What do you mean by "straight cut"? Got any pics of the issue? Did you measure the distance from the rail to the alternator? The only problem with the 90 NPT to AN fitting is, I always have an issue with it not "clocking" the direction I need it to without it being loose or way too tight. Don't know why Edelbrock just don't use AN on there rails instead of NPT.
Old Jun 21, 2012 | 02:54 PM
nonnieselman's Avatar
Why not go with a NPT to AN 90*
it will be alot tighter than a NPT to An straight and then a 90* hose end.
This
Summit Racing SUM-220652 - Summit Racing® AN to NPT Adapter Fittings - Overview - SummitRacing.com
Instead of this
Summit Racing SUM-220687 - Summit Racing® Hose Ends - Overview - SummitRacing.com
Old Jun 21, 2012 | 02:57 PM
With NPT, you can make it clock right.
or if your worried about clocking, go with something like this.
Hydraulic Fittings, Hydraulic Adapters, Brennan Industries - Product Display
Old Jun 21, 2012 | 03:28 PM
GetBlown01's Avatar
The NPR to an 90 that nonnie posted is what I was going to go with, I was just wondering if you guys see any issues with making that tight of a turn.
Old Jun 21, 2012 | 03:30 PM
GetBlown01's Avatar
Mcfarlnd, I was talking about a straight cut oring straight. But they don't make them in npt I guess.
Old Jun 21, 2012 | 03:39 PM
where were you goin to run a Oring fitting?
Old Jun 21, 2012 | 06:54 PM
GetBlown01's Avatar
On the fuel rail. But I just went and got a an to npt 90 like you suggested
Old Jun 22, 2012 | 11:13 AM
mcfarlnd's Avatar
Un-Registered User
Yeah, that's why I don't get why edelbrock don't use AN instead of NPT. Much better to use the fittings with the jam nut and not have sealing issues and you can clock it perfectly.
Roach Coach
Aug 30, 2015 10:06 PM
The_W
Aug 15, 2015 08:07 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
GMCtrk
Jul 17, 2015 06:39 PM
