fuel rail 90 hitting alternator
Quick question fellas. I just put the proflow xt intake and rails on. The problem im having is the front of the driver side rail 90 fitting is hitting the alternator . I have a straight npt to an with a an to push lock 90 on the rail.
Could I go with a straight cut straight to a 90 to bring it in a little, or would you guys go with a 90 straight off the rail ?
Why not go with a NPT to AN 90*
it will be alot tighter than a NPT to An straight and then a 90* hose end.
This
Summit Racing SUM-220652 - Summit Racing® AN to NPT Adapter Fittings - Overview - SummitRacing.com
Instead of this
Summit Racing SUM-220687 - Summit Racing® Hose Ends - Overview - SummitRacing.com
This
Instead of this
With NPT, you can make it clock right.
or if your worried about clocking, go with something like this.
Hydraulic Fittings, Hydraulic Adapters, Brennan Industries - Product Display
Yeah, that's why I don't get why edelbrock don't use AN instead of NPT. Much better to use the fittings with the jam nut and not have sealing issues and you can clock it perfectly.
Roach Coach
Aug 30, 2015 10:06 PM
GMCtrk
Jul 17, 2015 06:39 PM
