Fuel pressure woes
Old Feb 22, 2013 | 11:34 AM
  #81
AndysC3's Avatar
Looking at atomic's spreadsheet for fuel pressure, even at 60%idc I won't have enough fuel pressure with a single Bosch 044
Old Feb 22, 2013 | 11:42 AM
  #82
AndysC3's Avatar
I would have to set base pressure to 35 which would be too low
Old Feb 22, 2013 | 12:39 PM
  #83
oakley6575's Avatar
What injectors do you have?
Old Feb 22, 2013 | 12:50 PM
  #84
AndysC3's Avatar
FIC 1000cc 114lb at 58 psi
Old Feb 22, 2013 | 12:51 PM
  #85
Mangled03gmc's Avatar
Baltimore Whore
Run the pump, see where your at.
Old Feb 22, 2013 | 12:58 PM
  #86
AndysC3's Avatar
Yea, my fittings showed up today. All I need is the fuel line. O'reillys show that they sell it, And napa should have it. its the gates 27097 submersible pump. I can still run the inline bump if needed. to help out. Im saving up for a duel walbro 450 intank set up
Old Feb 22, 2013 | 01:05 PM
  #87
Baltimore Whore
I am also curious to see info from EFI live as to HP and TQ output based on the software. I think you are over shooting your hp a bit on guesstimating and calculators..
Old Feb 22, 2013 | 01:11 PM
  #88
AndysC3's Avatar
It has enough power to push my 5500lb truck from 0-60 in 4.2 sec with a 3200 stall converter and a cam that doesnt come in till 3600 rpm and shifting at 6500 vs 6800
Old Feb 22, 2013 | 01:21 PM
  #89
Baltimore Whore
I am not doubting the truck runs good, so please do not take it that way. I think however your pulling your hair out over a fuel set up when you do not have a real number to base it off of. Just like Roger said, when he ran his 11.x he was not making near the HP to the wheels as you claim you are making.. Ford L's made only about 375 at the crank and had a 0-60 ruffly in the same range and was only about 800 lbs lighter..
Old Feb 22, 2013 | 03:13 PM
  #90
AndysC3's Avatar
Yea. I guess. I just redid the math and I'm more like low mid 500s. It does run a lot stronger with the new fmic. Hoping the fuel pump will cure my issue
