Fuel pressure woes
#55
Baltimore Whore
Yes but wouldn't more flow = more supply, because of the volume of fuel the 2 are moving ? Same pressure but ultimately more flow//
Again I think 1 intake will be enough for that set up..
#59
Baltimore Whore
You need to order the sock for the pump, order a hot wire kit or make your own, about 8'' of fuel injection hose, 2 hose clamps, a barbed fitting to replace the check ball on the pump or a way to use the fitting with the check ball in it.
