Fuel pressure woes
#154
So I found 0ga wire on sonicelectronix for 85 for 20'. And I can get a power distribution box instead of having the wires held together with a bolt and would look a lot cleaner.
http://www.sonicelectronix.com/item_...X-XW0BL20.html
http://www.sonicelectronix.com/item_...TPGB-1448.html
#155
Anyone? And I'm starting to lean towards duel pumps from looking at atomic's fuel pressure sheet. Going duel walbro 400 with an adjustable Hobbs. Just have to justify the cost to the wife. Unless I can find a way to fit both Bosch 044 pumps in the bucket. But one was packed in there.
#156
I started the truck, romoved the vac hose, and tightened and loosened the adjustment bolt. still no change.
I just ordered two Walbro 400 pumps. should be here around Monday. Im going to use bolts through the top for the power, grounds to make sure I have good contacts.
