Fuel pressure woes
#23
I just don't have the funds or time for a duel intank set up. I already have the fitting ls to tap the rear of the tank and run another 044 and y it into the stock feed line on a Hobbs switch set to 4 psi. Would only cost me 250 for the lines filter and pump and could be installed in a few hours
#26
Yes I think we are on the same page. Reason for running the line to the rail is to eliminate only feeding the engine with just one 3/8 line. I would install the check valve before the pump, this maybe wrong but that's how I would do it.
Ask Atomic on running the hose to the fuel rail and how he would tap in for max flow.
I wonder if you could run a supply line to each rail and T the return line in the cross over?
Catch you later. Going to shoot my new in-line muzzle loader with my son and daughter.
#28
Mod with training wheels
I dont like the sound of 'tapping the rear of the tank'.....sounds like a good recipe for something failing. Youre going to want reliable in minot too... if you get stranded up there, its life threatening in the winter.
Do it once and do it right, or dont do it at all.
#30
I don't like the sound of 'tapping the rear of the tank'.....sounds like a good recipe for something failing. You're going to want reliable in minot too... if you get stranded up there, its life threatening in the winter.
Do it once and do it right, or don't do it at all.
The good news for Andy is that Stock48 tapped his tank along time ago and I have never read about him having any problems.
