Fuel pressure woes
Old Feb 24, 2013 | 11:58 PM
  #151
AKlowriderZ71's Avatar
11 Second Hall Moniter
Old Feb 25, 2013 | 12:01 AM
  #152
AndysC3's Avatar
What?
Old Feb 25, 2013 | 01:04 AM
  #153
AndysC3's Avatar
I'm also running 2 battery's. what can I do to the electrical system to get it up to par?
Old Feb 25, 2013 | 01:45 AM
  #154
AndysC3's Avatar
So I found 0ga wire on sonicelectronix for 85 for 20'. And I can get a power distribution box instead of having the wires held together with a bolt and would look a lot cleaner.
http://www.sonicelectronix.com/item_...X-XW0BL20.html
http://www.sonicelectronix.com/item_...TPGB-1448.html
Old Feb 26, 2013 | 09:44 PM
  #155
AndysC3's Avatar
Anyone? And I'm starting to lean towards duel pumps from looking at atomic's fuel pressure sheet. Going duel walbro 400 with an adjustable Hobbs. Just have to justify the cost to the wife. Unless I can find a way to fit both Bosch 044 pumps in the bucket. But one was packed in there.
Old Feb 27, 2013 | 09:50 PM
  #156
AndysC3's Avatar
I started the truck, romoved the vac hose, and tightened and loosened the adjustment bolt. still no change.
I just ordered two Walbro 400 pumps. should be here around Monday. Im going to use bolts through the top for the power, grounds to make sure I have good contacts.
Old Feb 28, 2013 | 06:05 AM
  #157
Choda's Avatar
Good luck man. Get it done
Old Feb 28, 2013 | 06:31 AM
  #158
03sierraslt's Avatar
Bolts through the top of the bucket?
Old Feb 28, 2013 | 08:40 AM
  #159
AndysC3's Avatar
Like mangled did in his write up
Old Feb 28, 2013 | 05:05 PM
  #160
AndysC3's Avatar
To keep space down, can I wire the neg on the pumps together and run one wire up to the top? Will use at least a 10ga wire. Then I will have two more bolts, one for each pos wire. Will this work or would it be better another way?
