Fuel pressure woes
Old Feb 23, 2013 | 07:33 PM
  #121
AndysC3's Avatar
The 044 is in. When I took the racetronix pump out the pump bucket was a different design and had a lot more room for the Bosch pump. Only needed minor trimming. I was able to take the connector apart and run the 10ga wire to the connector so I didn't have to drill the top of the pump. Starts up and idles great. Will have some road testing tonight
Old Feb 23, 2013 | 07:42 PM
  #122
GMCtrk's Avatar
Are you dropping the tank or lifting the bed to get to the pump?
Old Feb 23, 2013 | 08:09 PM
  #123
AndysC3's Avatar
Lifting the tank. Had 3 buddies. One on each corner. Lift and move back 3 feet. The bed rest on the tire and the bumper
Old Feb 23, 2013 | 10:58 PM
  #124
AKlowriderZ71's Avatar
11 Second Hall Moniter
Sounds like a clean install. The way you did it should work well, and looks alot more professional.
Old Feb 24, 2013 | 01:27 AM
  #125
AndysC3's Avatar
And still losing fuel pressure. My next guess is a bad fpr
Old Feb 24, 2013 | 02:08 AM
  #126
IDC% and RPM when fuel pressure starts dropping?
Old Feb 24, 2013 | 02:39 AM
  #127
Mangled03gmc's Avatar
Baltimore Whore
LOL yeh,,,
Old Feb 24, 2013 | 03:12 AM
  #128
AndysC3's Avatar
Max idc was 80% and it started dropping around 6200 rpm and 60% IDC. Would fall to about 40psi but would not go over 60 psi. I looked at my logs and afr started around 11.7 and went down to 10.6 so it's not going lean
Old Feb 24, 2013 | 04:01 AM
  #129
AndysC3's Avatar
here is a sketch of how my fuel system is set up
the regulator is referenced by a vacuum block that is attached to where the vac assist brake booster hose was. I have the fpr, boost gauge and the meth controller referenced to the same block
Old Feb 24, 2013 | 09:45 AM
  #130
Choda's Avatar
Not sure f it wil work for u but w mine when it got funky I would crank the pressure way in and way out while idle. The pressure would go from the min and max back and forth, it cleaned up and would hold steady after that. Maybe some gunk was on the seat or the spring had to be worked. It was free took 3 min and worked for me.
