Fuel lines? What size
Old Jul 11, 2016 | 07:41 PM
pewter00's Avatar
Default Fuel lines? What size
About to drop the 5.3 in my v6 truck. Engine is a 5.3 with heads, cam and nitrous. I have 8.1 marine injectors and an in tank Walbro in stock bucket. The stock v6 hard lines are still there but the soft line going to the tank/fuel pump has all been cut. Trying to figure out what size line and connectors I need to get.
Old Jul 11, 2016 | 09:12 PM
slvrram's Avatar
3/8" and 5/16"
slvrram's Avatar
fra-491990
fra-491992
Honestly if its a budget build, go to Oreilly's/NAPA/AZ and get the plastic ones in the above sizes with barbs then just use a fuel line clamp.
Old Jul 11, 2016 | 09:22 PM
pewter00's Avatar
It's not a budget build. It's a show truck I just decided to swap
Old Jul 11, 2016 | 09:25 PM
pewter00's Avatar
3/8 is 6an right? The nitrous kit I got from nx is all 4an. Will that work or no
Old Jul 11, 2016 | 09:40 PM
slvrram's Avatar
That's correct. 1/16" is 1 -an. If it's a show truck, I would cut the flex off both ends of the OEM V6 tubing, use tubing compression to -an fittings to connect either a ss braided hose or startlite/similar then to those fittings I listed above.
I'm not sure I understand your question about the NX system. Most people just adapt the fuel supply line to the test port on their oem rail. That's what I did moons ago at least.
vidan27
Mar 25, 2016 12:38 PM
Bdanielshd
Feb 25, 2016 03:32 PM
oxidizr
May 6, 2002 08:04 AM
tbyrne
11
Mar 7, 2002 06:14 AM
Phatchevy
Feb 7, 2002 05:37 PM
