Fuel filter before or after external pump?
Old Jun 23, 2012 | 07:16 PM
BlackGMC's Avatar
Resident Retard
Default Fuel filter before or after external pump?
I am planning out my fuel cell. I will be using a fuel cell with a sump feeding a bosch 044. I want to install a filter should it go before or after the pump? I am planning on attaching the pump directly to the sump fitting sooooo if the filter is before, how do i change it? All the gas would pour out.
Old Jun 23, 2012 | 09:10 PM
skeet's Avatar
dont know about others but i put mine after the pump up in the frame rail, then again once my tank is empty i flush it before adding whichever gas i plan on running on. then again for the last few times i done this its been pretty darn clean
Old Jun 24, 2012 | 12:11 AM
blown02408's Avatar
02 w/ lowest mileage 2800
I run the magnafuel setup with a pre and post filter and a shutoff in the line before the pre-filter. If running only one filter, put it after the pump.
Old Jun 25, 2012 | 09:17 PM
Phantom's Avatar
11 Second Club
definitely before the pump
Old Jun 27, 2012 | 02:01 AM
Noah Burns's Avatar
definitely BOTH... only way to do it
Old Jun 27, 2012 | 02:03 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Sock in the tank(pre-filter), then pump, then filter after the pump.
Old Jun 27, 2012 | 06:36 AM
LS1TRUCKGUY's Avatar
i like this setup the best... if i had to chose one, it would be after the pump...
Old Jun 27, 2012 | 07:44 PM
charcold-bowtie's Avatar
I had pre and post on my last one.
Old Jul 2, 2012 | 08:29 PM
Rudy91040's Avatar
Originally Posted by Noah Burns
definitely BOTH... only way to do it correctly
Fixed
Old Jul 2, 2012 | 08:52 PM
Byrdman11's Avatar
I always a sock or screen for pre-filter and big filter after the pump.
