Fuel cell
Old Nov 8, 2016 | 09:58 AM
121's Avatar
121
Default Fuel cell
I have a 2007 nnbs Rcsb. It's a ladder bar coil over setup with a RCI-2162a fuel cell. I want my factory fuel gauge to work and I've searched high and low how to do this. Nothing. Does anyone know a way or can steer me in the right direction!?
Thank a bunch
Old Nov 8, 2016 | 09:59 AM
121's Avatar
121
https://www.summitracing.com/parts/r...MobileSwitchNo
Old Nov 8, 2016 | 12:04 PM
Atomic's Avatar
I have a gauge for that
Easiest way would be to use a float sensor that is 40ohms full and 250ohms empty.
Old Nov 8, 2016 | 05:12 PM
121's Avatar
121
Atomic, How would I tie into making it work with my factory harness. It's three wires not two. I appreciate your help man
Old Nov 8, 2016 | 06:56 PM
121's Avatar
121
Old Nov 8, 2016 | 08:41 PM
Atomic's Avatar
The wires are power, ground, and signal. Should hook right up to your factory wiring.
What's your Vin and I'll get you a harness pinout.
Old Nov 8, 2016 | 10:18 PM
121's Avatar
121
Old Nov 8, 2016 | 10:19 PM
121's Avatar
121
Thanks a bunch man. So how would I wire the sending unit with two prongs and not three
Old Nov 10, 2016 | 09:12 AM
Atomic's Avatar
I attached the connector pinout.
So it looks like try your sender to Pins B and C on the harness.
Old Nov 10, 2016 | 09:36 PM
121's Avatar
121
Right on man! I have a 0-90 ohm sender in right now so I need to order the 40-250 ohm sender. Thanks a bunch
