FPR routing
There is zero advantage to that. The only reason to run an unreferenced regulator is if it is far away and would not be pratical to tie it in. This is the case with "returnless" systems. The name is a misnomer as there is a return, it is just inside the tank so you dont see it.
With boost, it is very important and beneficial to reference it, or you will have to massively oversize your injectors.
