Black-Ops Injectors
Old Jul 21, 2015 | 06:11 PM
DrX's Avatar
DrX
Default Black-Ops Injectors
Anyone used these injectors from Fiveomotorsport? I see they have 1200, 1300, 1400 and 1600cc versions if looking for something bigger than 1000cc.
Old Jul 21, 2015 | 07:26 PM
Choda's Avatar
I have the 60lb direct swap and they work great. Decent price and plug and play.
Old Jul 21, 2015 | 07:29 PM
GMCtrk's Avatar
Wasn't aware of those....really nice for them to be plug and play....although it does say USCAR connector yet no adapter needed? Wonder if they have all the correct data for EFI live. Price is very attractive compared to ID.
Old Jul 21, 2015 | 08:12 PM
DrX's Avatar
DrX
Sounds like they give you the voltage offset and flow tables and they mention the minimum pulsewidth. They have a few different LS styles. Since this website added a link to my post, I will include my own Black-Ops Injectors
Old Jul 21, 2015 | 08:17 PM
GMCtrk's Avatar
You could always be the guinea pig. I'm curious how the difference in low pulsewidth performance between the 1300 and 1600 cc injectors, because there's hardly any difference in price between the two it seems a no brainer to go with the larger injectors.
Also interesting....the truck injectors are listed as 45 mm......different from LS2 length of 48mm
Old Jul 21, 2015 | 08:38 PM
Choda's Avatar
Mine were 100% direct swap. No spacers or pig tails. They came w a data sheet that I have to Mike when he tuned it. I swapped them in his parking lot w gadgetized.
Old Jul 21, 2015 | 08:42 PM
GMCtrk's Avatar
Does your truck use multec II connectors like the 99-06?
Honestly, it's not a big deal, I already have USCAR to Multec adapters, but it would be great to get rid of extra wiring.
Old Jul 21, 2015 | 09:03 PM
DrX's Avatar
DrX
Looks like they measure to the middle of the 0-rings. Some measure to the outsides. That could be + 3mm.
Stated minimum PW of 1.4ms seems high compared to ID1000s at 0.125ms.
Old Jul 21, 2015 | 09:44 PM
MikeGyver's Avatar
Seems high? It is 11.2 times longer.
Old Jul 21, 2015 | 09:49 PM
George C....'s Avatar
Formerly ScreamingL
900 trucks use uscar connectors
