Black-Ops Injectors
I forgot to add. for these to work with my 2009 flex fuel truck I had to remove the top metal "hat" from the injector and the blue oring and re use the small black O ring from the stock injector.
The stock injectors had a small cap that slides over the injector and is held in place with a metal clip.
You have to use those. So I guess technically, they are not direct swap injectors. The black ops metal hat is pulled off with fingers or pliers.
