aeromotive 340
#31
I ordered the one that said for the red bottom pump, I didnt even see the second one you are talking about. Thier website is a little cornfusing to me. I havent installed it yet, but ill see when I get home tomorrow if it works as I will lay it out next to the truck.
#32
So I ended up ordering the Aeromotive 340.
First off, it does appear that there is a check valve.
I need to order a wiring kit for my fuel pump now and I'm a but confused.
It says in the small print on the racetronix website that there are 2 versions of the pumps, one white, one red. Now, I assume that any pump ordered today will be red. Where I'm confused is on which kit folks are ordering.
It says on the bottom of this page what kit to order if you have a red or white pump.
Racetronix - Fuel Pump Wiring Kit MP150/280, Walbro - Kit Configuration Page
Then there's this kit.
Racetronix - Pump Wiring Kit MP150/280, Walbro CK* - Kit Configuration Page
It goes as far to mention that it's longer for GM Truck/SUV applications.
What kit are folks using? The second one is roughly 10.00 more. It seems like if the only difference is wire length, one could easily solder in longer wires.
I emailed racetronix twice and haven't heard back from them. I'll be running this in a 2000 Silverado.
I ordered this kit along with Aermotive 11140 fuel pump for my 2003 truck but have not installed it yet. I hope I ordered the correct harness.
#34
Charlie Murphy!
Did you figure out which harness to order.
The only difference between the two is one is 12" longer than the other for SUVs.
Did you get the shorter kit to work? I haven't installed mine yet.
#35
Have not installed it yet. Havent even had time to fix an issue with some 8.1 injectors that I got cleaned. But I just got a set of smart fire injectors 52lb @ 43psi, new. Hopefully they are good just gonna swap over and sell my 8.1 after I take them back to get prepped for storage and he person I sell them to doesn't have an issue like I did with the flow fluid they use. Another reason is I have to work on he truck by myself and maybe 1 other and two people might not get a bed off, living in a subdivision sucks.
#36
This is the kit racetronix told me to get:
#37
Removing the tank and reinstalling it is a pain specially that you need to remove/hook up connections and hoses while the tank is up and you canno't see. Also, you need help to reomve the reinstall the tank. It is not that easy.
#39
11 sec. Truck Mod
I ordered my harness from lonnies performance so i didnt have to guess which one i needed, also on a 2000 silvy you will prob need the upgraded bulkhead connector that the newer trucks have, the old ones cant support the extra voltage.
