5.4 Lightning engine question
From: From Dallas,Texas stationed in Virginia Beach, Va.
Im posting this for a buddy. He recently bought a pullout engine for use in a pre-runner project and asked about how to do a compression check. I am not familiar with blown engines and I have never done a compression check with the engine not installed in the vehicle. Any one have a "how to" for this? What would be considered good readings? Thanks in advance for input.
I think he means that the engine isn't BLOWN kaboom but Blown WOOHOO. In which case he isn't to sure about the cylinder pressure readings. What psi should the cylinders be reading at when cranking over an engine with a supercharger?
as far as checking it without being in the truck, just put it on an engine stand, hook a starter on it and give it a crank.
am i right?
am i right?
He shoulda been more specific then. Still a leak down test will tell more. Compression will be a lesser number for a forced induction engine if it was built right. This is because you should not use forced induction on a higher compression engine. I would worry if the highest and lowest reading were more than 15% apart. Do the leak down on the lowest cylinders first to determine what is bad.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
