For you sts guys ???
Old Oct 7, 2005 | 08:42 PM
Mangled03gmc's Avatar
Baltimore Whore
Default For you sts guys ???
I was wondering if I could weld a flange to the back of my y pipe and put the turbo on there at the point. I would use the other things in the kit. This is possible correct. Let me here what you guys think. Or should I just put it in the place of the regular sts kit.Let me know what you think.
Old Oct 7, 2005 | 10:03 PM
TG02Z71's Avatar
I have thought about moving mine closer to the end of the stock Y pipe too. If there are not any clearance issues I would think it should help spool up some.
If you had an extended cab it will definetly be a better place!
Just remember, modifying the turbo's mount point will also modify the return piping to your intake somewhat.
Old Oct 7, 2005 | 10:20 PM
Wilde Racing's Avatar
How do I change this text
I think it can be done but I think you may have to run the pipe lower than the frame.
Old Oct 8, 2005 | 01:15 AM
duwem's Avatar
not the smartest idea if your gona pay all that money for that fancy long sts tubing, just build it your self.
Old Oct 8, 2005 | 09:18 AM
Jethro_3's Avatar
If you move it forward be prepared to biuld an intercooler as you loose the cooling of the longer exhaust and intake pipes.....
Old Oct 8, 2005 | 01:58 PM
Baltimore Whore
I was planing on doing a front mount in either case. I was thinking of doing the livernois kit but I can get the sts for cheaper and I just ordered these damn pacetters. How well will the headers hold up to the turbo's heat....
Old Oct 8, 2005 | 10:37 PM
bud8fan's Avatar
yep..you can put it where ever it will fit...the closer to the front the better...deffnit fmic thou...just have to make shure your oil return is gonna work proper and go for it....
Old Oct 8, 2005 | 11:45 PM
spitfire2332's Avatar
Just buy the detroit speedworks kit... mount that **** up under the hood IMO
Old Oct 9, 2005 | 01:13 AM
Baltimore Whore
I was going to do the livernois kit but i bought these headers and decided to go with it. so i guess I will see how this will work out.I will have over 1000 bucks to do other things with the sts kit so thats y I am going to try it.
Old Oct 9, 2005 | 12:27 PM
vanillagorilla's Avatar
You can do it, just have it do a 90* bend toward the tranny. Mound the turbo in there sideways (in relation the STS's mounting), that way the exhaust outlet and the comp. inlet and outlet will all me lined up properly for the rest of the kit to jive.
I plan on doing this in the future, but I'm going to be moving it foward in stages to see if I get any noticable gains. It's my effort to put the front mount vs. rear mount debate to the test.
