Will a stock fuel pump feed an 044
Old Jan 11, 2010 | 05:58 PM
Last Call's Avatar
TOTM: January 2007
As far as running the bosch or the 255 in place of the stock pump, I have the big bosch, run my tank down to 1/4 quite a bit, with out any issues.. As far as the dual intank, I think it is a PITA, when you can just do a big single, then your not getting into a dual bucket, hobbs switches ect.. So if you currently have a 255 inline, put one in the intank also.. Or keep the stock intank and put the bosch in place of the 255. Or cut your bucket up and put the bosch in the tank.. Here is a lil write up I did on my big bosch intank..
https://www.performancetrucks.net/fo...d.php?t=428535
Thanks for the info... If I am out of fuel, I will first try the 044 in line. If I am out of fuel, I will add a 255 in the tank.
Old Jan 12, 2010 | 10:24 PM
Hawk179's Avatar
Yes, that will work fine.
Old Jan 13, 2010 | 07:30 AM
BigCountryx's Avatar
You guys upgrading the factory wireing? I added a hot wire kit made for an F-body, it takes a couple of wire splices at the tank because the plugs are different, but the kit worked great and really steps up the wire gauge. May not be necessary, but I'm all about overkill.
Old Jan 13, 2010 | 11:34 AM
Last Call's Avatar
TOTM: January 2007
Perfect, thanks Rick!
I have a relay set up for my inline 255 using the fuel pump wire from the fuse block as the trigger. I have a solid wire running from the battery to the fuel pump.
What gauge wire did you use?
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Jul 21, 2015 02:12 AM
76k10chase
Jul 17, 2015 01:48 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
