Why is everyone METH HEADS here???
Old Apr 25, 2010 | 07:34 PM
kbracing96's Avatar
Originally Posted by Toomnymods
why would you want to spray pre-turbo? don't you need that heat to spool the turbo?
i always thought you'd want to spray if after..
where would the best place be for a remote mount?
Not on the turbine side, on the compressor side From the reading I've done, your cooling at the source of the heat so it's most effective, and also helps seal the turbo so it's a little more efficient
Old Apr 25, 2010 | 07:46 PM
Rocket468's Avatar
Yeap that's the benefit from meth injection when spraying at the wheel. Start cooling right at the source where all the heat is created .
I just recommend having a quality turbo in a nut shell you are spraying liquid on a hot metal part so the goal of the game is to start before the wheel is red hot. and also use a small enought nozzle and enought meth in the mix so you don't damage anything.
Old Apr 26, 2010 | 03:17 AM
Spoolin's Avatar
GFYS and STFU
If you do it before the compressor make sure you spray some well atomized dropplets. You start throwing some liquid meth at blades spinning 70,000+ RPM your gonna be looking for a new turbo.
Old Apr 26, 2010 | 12:04 PM
Compressor Surge's Avatar
If you are using it simply for cooling, then you cannot beat 100% water. It has a higher latent heat of vaporization than methanol, and it's CHEAP
Works fantastic on my NON-INTERCOOLED setup. Without the water, at the top of a 2nd gear pull, my IATs are around 210F. With ONLY water spraying, and no intercooler, my IATs are ~130 after the same pull.
You can see in this pic where I am injecting the water. It's just before the first orange silicone boot, right in the compressor outlet.
Old Apr 26, 2010 | 03:06 PM
MikeGyver's Avatar
Originally Posted by denali_on_26's
Why is everyone METH HEADS here??? ... and i think Meth is only one more thing to go wrong ...
I'm in full agreementship with the above inoculation. My reliance is heavily reliant on a double-sized reliable air-to-air inter cooler. When the cooling medium it requires relinquishes, the running of my engine will retire. I sure miss the octane boost that methanol provides, though.
Old Apr 26, 2010 | 03:46 PM
charcold-bowtie's Avatar
[QUOTE=Compressor Surge;4448886]If you are using it simply for cooling, then you cannot beat 100% water. It has a higher latent heat of vaporization than methanol, and it's CHEAP
QUOTE]
Mines not a truley fair comparison, but when I added meth my IAT's stayed ambient at 9lbs of boost. instead of like a 25* change
Old Apr 26, 2010 | 04:16 PM
ForcedTQ's Avatar
Lightbulb
Originally Posted by kbracing96
No, meth doesn't spool a turbo like N2O. It just a fuel, not a oxidizer that accelerates combustion
It's used mostly for cooling IMO
Would or would it not, if sprayed before the turbo inlet be considered a "quasi" oxidizer as well as a fuel. As its cooling effect pre-turbo would have the added benefit of creating a denser charge to compress, therefore netting a greater volume of O2 content post turbo? Just a thought....
Agree though, it's greatest benefit is cooling the charge post compressor!
Old Apr 26, 2010 | 05:04 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
While I agree that it IS one more system to break down or need maintenance it is a necessary evil when pushing the limits of compression with street fuel, expecially in states with lessor quality in the name of emmision control
Old Apr 28, 2010 | 01:04 PM
20 million Turbo Buick guys can't be wrong.....
LOL
Old Apr 28, 2010 | 07:35 PM
Rocket468's Avatar
i have done tons of testing. IMO an 50/50 mix is the best mix where you can get the benifits of both worlds.
