Who has tuned a FM turbo 5.3 with 01 ZO6 cam and 317 heads?
Old Oct 11, 2009 | 04:02 PM
1BAD_LS1's Avatar
Restricted User
Default Who has tuned a FM turbo 5.3 with 01 ZO6 cam and 317 heads?
Well i got done with my budget build front mount turbo 5.3 build in my 98 Trans AM.
I am currently working on the tune and was wondering if anyone had a tune i could compare to.... I am trying to work out some KR issues.
I am getting KR, AFR is good, Spark tables are conservative, IATS are cool, ECTS are 198-210, everything seems good but i a still getting KR i think its false kr.
I just wanted to see how my tune compares to someone elses tune with a similar setup....
I posted my tune and log.... I am open to suggestions and comments.
Here is my setup:
Junkyard Pullout 5.3 LM7
MLS head gaskets
stock 317 Heads with PRC Dual springs (giving me like 8.7-8.9 compression)
02 ZO6 Cam
Comp 7.425 Pushrods
ls6 intake
ported TB
FMIC
Master Power T70/.96AR Turbo
Homemade merge pipe/downpipe dumped by starter
60# injectors
NGK 8 racing plugs gapped at like 28 (cant remember for sure)
stock wires till the MSD's i ordered show up
stock tranny
VIG 3600 stall
stock driveshaft
Quick Performance 9" 3.70 posi
3 point subframe connectors, lca's, stock tq arm
summit stars, mt radials, mt skinnies
Thanks,
Blaine
File Type: hpt
File Type: hpl
Old Oct 11, 2009 | 04:25 PM
dirt track racer 81's Avatar
how much timing are you running..
Old Oct 11, 2009 | 04:59 PM
slowlsx's Avatar
his file shows between 5-9* at WOT
Attached Thumbnails Who has tuned a FM turbo 5.3 with 01 ZO6 cam and 317 heads?-untitled1625.jpg
1BAD_LS1's Avatar
Restricted User
24* is the highest across the whole table.... starting at .68gcyl 12* tapering to 4* at 1gcyl
it should be plenty low....
I know it looks a little butchered up... but thats an attempt to get rid of the KR
Old Oct 11, 2009 | 05:12 PM
slowlsx's Avatar
how much boost are you running?
Old Oct 11, 2009 | 05:30 PM
1BAD_LS1's Avatar
Restricted User
11 psi....
I read somewhere that the 5.3 had oversensetive knock sensor settings in 99 and thats what i was using so i changed the knock sensor setting to an 02 settings (from a tune in the repository)
Im thinking it is false... i havent tried high octance fuel yet because nobody sells it around here.... but removing as much timing as i did (where its at now) whould have reduced the KR or removed it but it didn't!
Old Oct 11, 2009 | 05:59 PM
slowlsx's Avatar
Originally Posted by 1BAD_LS1
11 psi....
i herd the same thing! i would try that and see what happens... you have very little timing for it to have all that KR.
Old Oct 11, 2009 | 06:11 PM
1BAD_LS1's Avatar
Restricted User
anyone have a good place to start to make the sensors less sensetive but not to sensetive that they wont pick up detonation????
Old Oct 11, 2009 | 09:00 PM
1BAD_LS1's Avatar
Restricted User
i was looking the log file over really closely and noticed that the KR under really light throttle most always happened at 50-65KPA.... Im gonna try to enable the PE table sooner and see what happens.
Old Oct 13, 2009 | 07:36 PM
TURBHOE's Avatar
i don't think you can just load 02 settings into a 99 ecu and have it work. most people actually do a full rewrite from a 02 ecu tune. that will fix the "issues"
